17' Series Advice on most efficient use of A/C
MatandSash
5
Mildura, Vic
Right, it is humid as Darwin in Adelaide at the moment. I'm interested to see how you use your air con for best performance while in bed. It seems we are just getting no airflow in the beds. Apart from the little clip on fan. All Windows and door closed. Air con is working a treat when you stand under it? Expanda Outback 17.56.1.
Any suggestion appreciated. Going to be another sticky one tonight.
We have the Ibis 2 in a 20ft OB. To be honest we rarely use the aircon at night, but the vents angle down perfectly and blow straight into the bed.
The van maybe longer but the roof middle point is only 600mm difference.
We have Caframo Ultimate fans that are generally enough for us at night, but in your case a strategically mounted Caframo could be what you need to redirect the cool air. In the interim a $15 Woolies, Coles or Bunnings fan should sort you out pushing the air where you require it
(Nice choice of vehicle too ;) )
