hi I have an expanda with 120w roof solar panel. Uses the installed factory regulator with no problems. I want to add in my portable panel to the same battery when required as I can direct it to the sun and achieve more amps. It also has a regulator that I would like to put straight on the battery. Will two seperate systems cause more harm than good? I don't want to destroy the battery, regulators or the drifter panel.
It's a pain in the arse but I could run the wiring to the installed regulator then it's all though the same system.
Any thoughts guys. I'm sure this has been done multiple time before.
