So I have just ordered a bunch of things through Caravans plus so I can hook up a 12v pump from water tank to join into the mains pressure line.
From the tank it goes into a 30mm clear hose which reduces into a 16mm clear which is used to the hand pump. I will mount the pump under the chassis and I want to T into this 16mm hose. The only thing I could not find from Caravans plus was a suitible T piece.
Can anyone point me in the right direction to find a 16mm - 16mm with a 12mm T of of side. Or simply a 16mm T then a 16mm to 12mm reducer.
This is all under a new 14.44-4 OB if needed to know.
Also while im here what is the easiest way to run 12V under the chassis. I dont even know where the battery is yet
