Thought this may be of interest to some people:
New 17.56' OB Expanda
I upgraded the 12 volt power system to work when we are fully bush, it helps that I have a sparky back ground so can do it myself easily.
Van had 1 x 100Ah Gel cell and 1 x 120 Watt solar panel out of the factory.
One consideration we had was that the fridge is a 12/240volt Weaco compressor fridge so when we are away from power, we draw more than we would if we had a 3 way fridge.
Supply Gear added:
1 x Redarc BMS 1215 - Battery Management System -
2 x 120 Ah Batteries (2 x AGM sealed lead acid)
1 x 200 Watt solar panel
1 x 150 Watt solar panel
1 x 12 volt solar input plug on non door side of van - For portable Solar panels when parked under trees
Heavy duty 12 volt supply line with Anderson plug from car
Output gear added:
2 x external 12 volt outlets - 1 at front, 1 and rear on door side of van - for fridges
1 x outlet internal next to lounge seat (For waco whilst travelling
1 x External 12volt outlet on non door side of van
3 x 12 volt fans - hard wired and mounted
1 x LED light fitted to backside (Non door side of van)
Internal 12 volt outlet for fridge
Overview of BMS and battery cabinet
Air circulation fan added to BMS cabinet
Battery 2 & 3 compartment
12 volt layout
12 volt layout
One of the mounted 12 volt fans
Supply Gear added:
Output gear added:
12 volt layout
12 volt layout
