Howdy all,
I have searched the forum with some succusses but in the main I need a basic view on whats the best.
As I have my van being built currently, im now sorting the best way to charge batts/fridge whilst travelling, and after speaking to the dealer on options, I am now even more confused.
To give you some back ground info, my veh has a dual batt system, with a basic red arc isolator incorporated, I currently run an Anderson plug to the rear of my veh to charge batts on the move...standard stuff. I also have a 7 pin plug for elec brakes and lights etc...
My basic understanding on the van set up for touring is that whilst connected I have power going to the batts/fridge, and when you stop you will still have power running to the fridge, therefore draining your batt unless you switch it off, or across to gas...??
So my questions are in a few parts I guess.
1. is it possible to keep my 7 pin plug and Anderson plug to charge the fridge and run the brakes, lights etc ??
2. do I need to an isolation/battery switch for when I stop driving to prevent problems etc
3. lastly, whats the best way to do this, what have others done with your set up's..
Thanks.
Rooster....
Thanks.
Rooster....
