Had the same problem, , Pull the plug right out , pour in a mixture of carb soda and a quantity of water and let stand .It will fizzle for a while while at the same time cleaning all the scum in the accumulation area. Using a high pressure water jet ( garden hose ) give it heaps. Place a bucket under the outlet ,You will be amazed how much scum comes out. I also repeated the process using the green Aqua Kem ( used as a toilet additive ) leaving it soak for 10- 15 mins. Apply pressure hose to flush. Gave it a test by running the garden hose into it and found it drained away nearly as fast as was filling. I think the underside of the basin collects the water and in turn exits the drain pipe ,so if that is full of crap it won't drain.
Good Luck, Brian B
Good Luck, Brian B
