16' Series Heron 2.2 aircon leaks
JC1
Hoppers Crossing VIC
Gday All,
I've got a 2008 Jayco 16.49-1, with a Herron 2.2 wall mounted aircon/heater. Water leaks from what i guess are the filters, when aircon has been on for awhile. There is a 10mm diameter clear pvc tube, going from an elbow joint at back LH corner, around to the RH filter.
Is this correct, or should it be leading to the outside of the van?
Thanks...JC
19,492
The box where the air comes out has a drain which should run to outside thru floor, usually thru some cupboards, thats is probably clogged or the drip tray is cruddy, lift the vent on top of the cupboard it lives in, should give you enough access to look otherwise you have to remove the front panel..... dust, dead bugs .
How they ran it when built is anyones guess.
JC1
Here's a pic of what i can see - the drain looks set over the filter
