20' Series BlackJack Trailer Jack
facemir
24
Gold Coast, Australia
Has anybody installed a BlackJack trailer Jack on their 20.64-1. I was wondering about the height of the jack, and whether it would hit the bed end when its out.
19,470
I see on the site it has 520mm from bracket to top of unit so that gives you an idea if it would foul the bed end so you would probably need 550mm at least clearance from fraw bar to bed end just to be sure.............. I have no idea of the gap though on your model.
Its a very pricey unit I suppose wire it up so you plug it into tug so don't chew van supply, then you have the weight of the thing at 17Kg..... I have a ALKO side winder jockey wheel which is by far better than the standard units, I can wind up using 2 fingers and at $100 its cheaper and doesn't add to the ball weight......
