You need an Echinda, the Environmently Friendly Ant Rid............................ Ant Rid seems to work but other stuff is suspect I have found.....
I have washed half of Big Mal so far, bluddy red dirt my lawn is Red now, will take a few days for ground to dry, then I will have to find another excuse before I tackle the damn bearings/brakes ....................... tempting to call someone but I know I won't trust them and they will want money in exchange for a suspect job............ I'm hoping I can get away with a bearing shake then pop one drum off to check brake condition if that one is okay then rest of them just get a bearing shake, if good won't pop drum off ............ One voice says "Good plan" , other voice says "You Lazy Bustard" removing hearing aids I can still hear him............... Jeep has been serviced, cleaned , should check pads and rotors on it as well, bum........
