water pressure another stupid question...
Discussion in 'How To's / FAQ's / Technical Documents' started by Glenn42, Jun 26, 2013.
  1. Glenn42
    Glenn42 New Member
    Jun 26, 2013
    6
    pretty sure my mains water pressure regulator is R/S my question is do you really need this....the inlet to the reg is still the black plastic piping complete with push on style fittings, with this in mind the inlet side must be able to handle the pressure then why cant the rest of the system??
    Glenn
  2. Glenn42
    Glenn42 New Member
    Jun 26, 2013
    6
    Must of been a really stupid question
  3. AndrewC
    AndrewC Active Member
    Mar 20, 2013
    207
    232
    Murrumba Downs, Brisbane
    I think you will find that the internal tapware and hot water service is not rated over 350KPA. I have tried mine carefully without the regulator and the flow pressure is not much more.
    Some towns you go to may have extremely high pressure and some may have above average pressure and you might not realise. Comments have been raised in the past on other forums about just turning the tap that feed the van on less. But, the problem is when all the taps in the van are closed, the pressure still remains the same and you have only really reduced the flow rate.
    The pressure reducer is there to stop you blowing your fittings to bits and having the dreaded water leak in you van. All vans generally have them. Things like campers sometimes don't as they do not have HWS's in them. When you add a hot waster, it time to add a regulator.
    Can you imagine coming back to your van after being out for a couple of hours to find a pipe has failed!!
  4. Capt. Gadget
    Capt. Gadget Obsessive & Compulsive Gadget Man
    Dec 1, 2011
    1,860
    1,741
    Sunny Northam W.A.
    Home Page:
    I've heard of regulators being put on the wrong way around and I had a non return valve fitted in the wrong place so that the tempering Valve wouldn't allow the hot water to work when using the Pump
Share This Page
