Hello all,
Just a Jayco 'Newbie' with a S/H 2009 Penguin with an annoying water leak below sink at those seemingly useless black spring loaded compression type quick connect fittings. Am about to replace with combination of 12mm garden type irrigation fittings with S/S hose clamps to prevent more leaks! Any better ideas forumers? I have tried using Silastic 732RTV( the 'good' stuff) smeared over the 12mm black high density polytube and reconnecting and allowing it to dry but when hooked up to mains water or when electric pump/sinktap turned on the bloody leaks occur again! And ..yes I have inserted those grey pipe end reinforcers from Jayco and it still leaks from the quick connectors.
Cheer's
Mact
Cheer's
Mact
