17' Series Van on mains water - Nothing
Duncanblake36
103
168
Doreen
Hey Guys,
Dumb question time. I've had my van for 2 years now and have never used the hose directly connected to the van. I've always used the water in the tanks and the pump. Today I was cleaning out the water tanks and hot water system (after winter) and getting it ready for next weekend camping and plugged the hose directly into the van and nothing. No water coming out of the taps. Is there a special button or leaver you need to pull to use the water. Whats the go?
19,992
First check the hose coupling on the end of your hose, if it is a stop valve job you may find the van fitting isn't opening it up otherwise remove the hose and fittings from PRV valve to inlet socket and check for blockage, could be a nest has been built in there so once you hook up you just end up blocking the line, it can get to the inline filter and clog it all up so you end up with no water, pop a connection under the van before the junction to the pump and see if it flows if not then pull it down till you find the blockage.
Reactions: Duncanblake36
