Interior Thetford C400 series Toilet pump
Jaybird
146
38
Loch Sport Victoria
#1
Does anyone know how to remove the pump after the control pane etc is off. It doesnt just lift out as per Thetford instructions. There must be a trick to it before I lose anymore skin.
Four of us
365
120
Ipswich QLD
#2
Mate, after you remove the panel run you hand down inside the water and you should feel the pipe that connects to the pump. Just it a bit of a pull and you should be able to pull the pump out that the hose is connected to.....it has worked for me as I’ve had to replace the pump before....
G Daddy
272
373
Toowoomba
#3
as aove just need a small hand and a it of jiggling, I replaced my pump with one from a 12v portable shower much cheaper and still going after 3 years
Jaybird
146
38
Loch Sport Victoria
#4
Thanks for replying, I gave the pipe a good tug and it unclipped the fitting that goes into the bowl, I think I will try and get a more flexible hose when it goes back. The impeller was jammed solid. Some silicone spray and away it went, the hose itself had no flex at all. Not sure how long it will last.
Jaybird
146
38
Loch Sport Victoria
#6
I just put a flat blade screw driver under the edge and very carefully levered it up, then unclipped the wiring and then pulled out the next tray that the wire goes through and then you're in.
2,963
3,288
Sorry to be bearer of bad news but yeah it won’t last. Get a pump now I bought some from the UK heaps cheaper than here even with postage.
Jaybird
146
38
Loch Sport Victoria
#11
Well pump now fixed but you gotta ask the question who would design a unit with an opening smaller than the average persons hand when all it needed was an inspection hatch that you could unscrew that had all the switch etc attached. Be prepared to lose skin and practice you're yoga flexibility exercise before starting.
