The Tuckers 18.58-2 Outback
Tucker
223
327
Geelong, Victoria
my cross bar is closer for some reason 10.5 cm from last bold to bar :( .. I have to take off like 4 or more gears to make it fit.
Got a couple of other options although not sure how legal a spacer is anymore I also rather not change the handbrake setup.
They are a nice piece of gear I heard no problems at all with them. Still upset I cannot get it to fit
That sucks you could always reweld the cross bar further back and prime and gal paint
thats another option I rather not play with the A frame.
Also put it on a 50mm spacer that get it above the crossbar
Someone else put theirs on a steel plate re drilled holes so moved it forward.
Both of these fuzzy if legal into not fuzzy :) if you know what I mean.. insurance wise.
All of them a pain in one way or another..
Let me know how you go.. I think I go for a ARK offroad one as handbrake the same as ALKO.. McHitch same problem with handbrake
Tucker
223
327
Geelong, Victoria
I have seen a couple with the 50mm spacers but not sure of the legal side of that so I don't know what your options are I can't see the problem getting the 20mm x 20mm box cross bar properly welded if it was the main chassis box section I'd say no but anyway good luck
Maximage
68
73
Have you got the V3 davemc? I didn't measure ours when I fitted it, so not sure what distance is normal, but I fitted a V2 by removing and welding in a new cross brace, to then find out a week later the V3 had just been released and was shorter, so fits without modification usually. Not happy! :)
@Maximage Yes it is a V3 still does not fit cross bar 10.5cm from last bolt.. McHitch no good at all I have to use something like the ARK which has the normal handbrake like the ALKO.
Tucker
223
327
Geelong, Victoria
mod number 1 for the day the kids safety bed net extended to stop my 3yo from wondering around at 3am
Reactions: Drover and davemc
19,469
Did you put a loop in the drain from shower drain to stop any blow back ???
19,469
Just wait and see, sometimes you can get some flow back into the shower, sometimes not, just depends on the way the pipes are plumbed I think.
Tucker
223
327
Geelong, Victoria
Well you won't believe it I know I didn't we where all at Safeway our 5 year old walking next to me my wife with our 3yo in the trolley and I was carrying our 10 mo. There was this Safeway bloke staying near us where ever we went and I was starting to think " what does he think I'm going to pinch something do I look sus" (hence covered in tattoos and neck tatts which when we where in qld they wouldn't even let us into a licences venue cause of neck tatts then he comes up to us and said look its Christmas and Safeway would like to give you $250 for your shopping we where gob smacked my wife started to well up and I thought he was taking the don't be rude in the end we couldn't believe our luck and u couldn't thank that bloke enough it did make out holiday
19,469
Well, now thats for a Merry Xmas..........:cool:......................................brilliant, :cool-new:
