expanda, looking at image that ends in 502 the one from the front with awning out, noticed that there looks as if there is an additional piece kind off reinforced piece of material on the awning coming away from the van, OR is this the color. i thought that color shading is towards the roll.
does any else have this?? Pace.
Hey pace, nope just the colouring no reinforcement
Maybe its silicone???
Wow, what an adventure already. Keep the updates coming and i hope the mighty Pathy is back on track soon for you.
PS I still love this layout, more photos please:yo:
Another convert !!!
More pics coming once I get the car back!!!
Good story, expanda, with some good pics as well. Top cover with NRMA or RACQ up here is a must, well worth the extra cost.
Hopefully you will be up and running sometime today. Looking forward to catching up again on our home patch later in the week.
P.S. Elaine says we will have one of the same if we could get the same deal you did. :jaw:
Sounds good mate we are looking forward to it as well !!!
And let Elaine know she should come down and check out the van in the flesh.....
Nope, no towing just local driving. If I had been towing probably would have had similar symptoms to you.
Yep its lucky you weren't towing let me tell you it was certainly entertaining !
It almost looks like that pipe needs to be a flexible braided hose :noidea:
Although with the heat of the turbo it would only have a certain servicable life.
It doesn't look that strong but the mechcanic told me its a high pressure pipe that needs to be a genuine fit.
That said if the part doesn't arrive today I may just go down this path and do it myself....
They have changed the material composition to one which is not so affected by oil but I have also blanked the EGR so no oil is passed back through the pipe.
Interesting points!!!
I think that is what went on ours quite a while back also.
Ours was still under warranty back then so Nissan just replaced it.
Keep up the pics expanda. Nice looking van.
Seems to be a common fault then by the sounds of it maybe time a sticky for all pathy owners to carry some magic tape to seal the pipe when it eventually does go !
I broke down last school holidays towing the van to Jayco (auto electrician stuffed up the Anderson plug wiring very big time) but I had the factory road side assist which towed the car to the dealer (Toowoomba) but I had to pay to have the van towed behind. I believe the car cost just under $2000 to tow ($2000 is the limit that road side assist will cover) and the van cost $350 to Toowoomba plus another $160 to Jayco in Brisbane. Was an expensive first service but could have been worse......
OUCH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Not sure how much it cost to tow the pathy and van up here but i am guessing it wouldn't have been cheap.
