Hi all,
Just after confirmation that i'm not barking up the wrong tree with my intended portable solar setup.
The Setec instructions say,
So what i,m proposing is
Any comments?
Turtle
Mate, you are spot on with what you are trying to do. Cool drawing too!
Is the anderson plug going to be on the drawbar for charging while driving as well? If so, make sure the cable going out there is 6B&S to ensure that you are minimising voltage drop issues. The cable from the solar panel/regulator can be left at what came with it.
Also the fuse needs to be rated to protect the cable so if it is 6B&S, make it a 30A to start with. Smaller cable sizes will have to have a smaller rated fuse as required.
Gil
Thanks Electricguru,sounds straight forward however would you mind posting a diagram including cable sizes, that would be really appreciated.
Sorry to dumb this thread right down...but...can I just buy one of the folding solar panels with built in regulator and run it through the van window straight to the battery and expect it to charge?
Thanks guys. I tossing up whether I will really need it at this stage. I have just converted the lights to LED and the fridge I run off gas when off the grid. I have dual battery in the car running the engel. I should be fairly self supportive for a while with that set up? How long do ppl generally get out of their batteries before requiring solar to boost things along with general light use?
