Sterling Replace ceiling lights with LEDs
Glen Bundesen
336
212
Perth WA
Are the ceiling lights the same in all 2011 Jaycos? I want to replace them with LEDs but can't see how to get the existing ones off the ceiling?
Glen Bundesen
336
212
Perth WA
there are about 10 of these ceiling lights - if they are a sealed unit then I possibly cant replace like for LED like?
There are round flush mount LED on the caravan accessory market, and Jayco did use some variation of them at one point if not still. If you search the InterGoogleWeb, or some where like www.caravansplus.com.au, youll find flush mount LED to replace yours which are almost like for like, or maybe with a more modern look ..... but ..... if they are caravan accessories be prepared for your "wallet" to be reamed.
Mounting is only 2 wires, so the mechanical side will be pain free, but not so much the purchasing side. Ouch
These are on www.caravansplus.com.au for around the $40 each area
mini_downlight_30led_silver_70944l.jpg e-12V-LED-118mm-Ultra-Thin-Surface-Mount-Light-caravans-plus-spare-parts-accessories-RVl.jpg
Glen Bundesen
336
212
Perth WA
Thanks for the info Crusty. I had a look on ebay and after checking the size may get some for $14 each.
BTW - do you know how those in the ceiling are fixed in as I didn't like pulling too hard?
No real clue in the fixing, but I would run with screwed in. Anything affected by gravity and fitted by Jayco would most certainly have fallen out by now without screws
