Hi Big Al, I'm assuming you are talking about the clearance lights at top? Just get a flat blade screwdriver and gently pry the side clips open a bit, (away from light) only need to do one side and then you can pull light out. That will leave the plastic backing plate which is screwed onto fiberglass. Hope that helps!
