Hi Dingo
As said before it comes already pressed up on a sheet of board then cut to size.Certain colors are available in a laminate but it is approx 1.5mm thick that needs to glued to board using contact glue available at bunnings.You cant actually buy the paper and do it yourself,hopes this helps
