JTECH air
3,031
3,401
Yeah cool that was my thinking too. But I did find another wireless system that has presets and the pressure gauge on the remote! Prob is it can’t run through a air tank so could see it being very slow !
Reactions: Base23
Base23
465
1,083
Air suspension system installed.
Was not an easy job as most of the install was done lying under the van, lots of cutting, grinding and welding. The kit itself is quite good and every thing you need is supplied. Have not towed it yet but going up and down in the shed is fun.
Here are some completed pics.
20180822_194059.jpg20180822_075609.jpg20180822_075507.jpg20180819_225416.jpg20180818_124055.jpg20180818_123830.jpg
Reactions: Jake
View attachment 61530View attachment 61531View attachment 61532View attachment 61533View attachment 61534View attachment 61535
Cutting and grinding are no problem, but what are we welding
Reactions: Bellbirdweb
welding new lower shock mounts, top air bag mounting plates and bump stop mounts.
I imagine you'd (read I) would want to be a qualified and experienced welder to weld on shock mounts? Im pretty sure were my shock mounts would end up if I welded them on :confused:.
Reactions: G Daddy
Base23
465
1,083
I am not a qualified welder but have been welding for many years.
use good (correct) welding rods and practice many times before welding.
never had a weld break yet.
Reactions: Crusty181
Base23
465
1,083
Would you be able to upload a copy of the install instructions for us to study?
Not sure if this will work but have attached a copy of brochure and instructions.
  • WTA4TAJINS_v2.pdf
Reactions: achjimmy
