Yes mate, I put the stabiliser legs down before jacking aswell, so something can catch the van in this exact case. Was on flat surface too. Biggest problem is these jacks and the design of their use is crap on an outback where the chassis is raised.Did you have the van hooked up to a car and chock the other wheels, hope you didn't get hurt.
I had to use mine a few months ago to change a flat and had no problems.Yes mate, I put the stabiliser legs down before jacking aswell, so something can catch the van in this exact case. Was on flat surface too. Biggest problem is these jacks and the design of their use is crap on an outback where the chassis is raised.
Good move @chartrock and glad no injuries occured (Apart from maybe some pride if anyone was watching)I have removed my scissor jack and replaced it with a 4000 kg bottle jack purchased from Masters with 40% discount..
Also don't use a hi lift jack on your van unless you really know what your doing,
Yep. Bottle Jack for me.
Can anyone recommend the ideal extended height?
And rated for how many tons??
I've considered the trailermate or the boss but want to keep things as simple as possible and easy to stow...and relatively light as I'm over lifting heavy things.
