Interior How do I remove the little insert in the pantry
Macca_75
680
596
SE Suburbs, Vic.
Hey guys,
Wanting to wire my new fans on the bunks to 12V. I need to get access to the wiring in the food pantry, on the top shelf (for the top bunk on the other side of the wall).
Does anyone know how to remove the little "fake" back wall in there? I can't see any screws so am hoping it's just screwed to the top shelf (from behind) and if I drop the shelf out the fake wall will come with it.
I can't see any screws holding it in place anywhere.
Thanks in advance.
Jayco only use universal corner brackets, so if you cant see any inside the cabinet they'll likely be behind it. The cabinetry is pre-made in modules so a false back is likely connected from behind
Reactions: dagree and Macca_75
Macca_75
680
596
SE Suburbs, Vic.
unscrewed the top shelf and it wouldn't budge so it must be screwed from the back prior to putting the outter wall on.
I ended up pulling the 240v from the bunk side of the wall, getting my hand in there and feeding the 12 cable through with the rest of the other wiring looms. Job done.
