Has anyone else come across attaching castor wheels to a van when they have problems with grounding out on a steep hill. (I should have linked this in with another post "driveway from hell")
We cannot reverse the van round the corner onto the driveway and vice-versa get out as the rear bar will always ground out on the driveway.
It was suggested that we can solve the problem by adding some castor wheels on the rear end, so after some research I bought a pair at the weekend, each wheel is rated for 350kg.
The plan is next to weld the wheels onto the rear of the chassis, at a point whereby it will just stop the rear bar from hitting the tarmac. We have pushed the rear bumber bar in further which should help a little but still need to insert some additional metal to get the right height for the wheels to work.
Now just need to find a friendly welder to do the job. Has anyone tried using castor wheels before ?
