Foxtel GO or Mobile Foxtel Airplay & AppleTV
Gadgets 21.63.1
aka - adam 18.57.9
Jun 29, 2013
398
156
51
mornington peninsula victoria
www.bifolds.co
trying again - i did copy and paste before, now i am saving to file and attaching
Gadgets 21.63.1
aka - adam 18.57.9
Jun 29, 2013
398
156
51
www.bifolds.co
permanent vachum. power supply goes through to in the cardboard with power points on the inside. also with the uhf base station. but if you look closer at the benchtop you will see i have taken the plastic edging off and spun it around. now there is a lip above the bench. this stops anything falling off when towing. like remotes or anything like that.
Gadgets 21.63.1
aka - adam 18.57.9
Jun 29, 2013
398
156
51
www.bifolds.co
foxtel 3 way input, also tv mounting bracket, also a data point there for tv, this uses audio send and return for the tv, as the speakers are mounted behind the fridge vents which is controlled by the next picture. amps inside. just a dummy plug in the socket for travel to stop dirt getting into the socket. if you dont want the tv there for a single night but still want the music, then a bypass plug is inserted into the socket, which patches the audio back into the socket, so the amp inside thinks there is a tv outside and the sound just works only outside.
Gadgets 21.63.1
aka - adam 18.57.9
Jun 29, 2013
398
156
51
www.bifolds.co
camera we use to watch our 2 year old asleep. when we are outside, so we know she is all good. we use the ipad or iphone to check up on her, also have wifi repeater to give 200 metres of range for internet access for our wifi devices. netwkring also under each seat and at the end of every bed. as we have 4 kids in school, when we travel, they can log into school and keep up to date with there work each day.
