Hi
We have a 16.49.1 and were looking at fitting another water tank. On inspection of the chassis there is room for another Jayco 90 ltr (400 x 1270 x 350). Our first tank is fitted in front of the axle and the available spot is around the same distance behind the axle. The only problem is the gas line runs along this section. Are u able to mount the water tank over the gas line? If so do u protect it with anything? We r not very technical in this regard! Any advice would be greatly appreciated.
