Sorry to Hijack the thread guys.
But im about to order this Diesel heater,
http://www.heatso.com/eberspacher-airtronic-d2-12v-2-2kw-heater-kit/
Now im wonerding which controller to order and which is the best wort of fuel tank, i only want a small one.
Thanks guys,
This is the kit I ordered a couple of weeks back. I optioned the easy start select which is the most basic controller. With a mounting plate and postage it came to $995. You may run the risk of having to pay an extra 10% total with a more expensive controller as it will put you over the $1000 threshold.
I find the basic control good with a digital display showing set temp and ambient room temp, the 801 I believe is pretty much the same just the older version (could be wrong) the next one up includes a timer function then the top two are remote start.
If I was to order it again I would stick to the basic one I got as I can't see the others worth the extra $$$. Before I chose I check a table on the eberspacher website which compared the cotrollers and function. You could look that up too.
Fuel tank, I just used a plastic jerry can, on rear bumper. There is a nice slimline 10ltr one you see online. It would depend on where you want to mount it. 5ltrs is probably more than enough, but I ended up going 20ltrs which I will only fill if I wanted extra (just in case fuel) for the tug.
