Hi all,
On the last two trips we have had a problem with the anti-flap kit on the awning towards the back of the van. Unfortunately I do not have pictures of the original problem but I think I have pictures of the course of the problem.
The problem is that the rear anti-flap kit does not clamp onto the awning all the way and the last 30-40 cm of the awning is continuously coming out of the anti-flap kit.
The awning / annex has been set up a number of times with no problems, but the last 2 times this has been a problem.
So I have checked a couple of things and the issue seems to be that the awning size has changed from the top (caravan end) to the roller end by about 2-3cm. The awning width is smaller at the roller end.
I have included 4 pictures showing that the awning width at the caravan end matches the mounting points for the anti-flap kits (both front and back seem to mount the same (and close to the line of the awning); However at the roller end the front mounting hole is correctly but the back seems to not match the current width of the awning.
Some my conclusion is that the awning has shrunk or gathered at the awning end. Is this the right conclusion?
The important thing of course (which I am not sure of) is how do I fix it? I do not want to change the location of the mounting hole. I am hoping that someone may be able to tell me how to loosen the awning on the roller, then allow me to stretch it back out and then tighten it back up on the roller so that it stays in the correct location.
Any suggestion, hints, discussion would be much appreciated.
Steve
Steve
