To put things simply think of 12 volt power like a recirculating water system, that tank is your battery, the hose is your wire, the tap is your switch.
Voltage = how full your tank is
Wiring size = how big your hose is
Amps = Flow through your hose
You cant measure Amps if there is no flow (load)
The bigger the hose (wire) the better the flow (amps)
The fuller the tank (battery) the better everything works
Imagine if you cut the hose and put a water wheel (lamp) in the hose and turned on the tap (switch) the water would flow from the tank through the switch(tap), through the water wheel (lamp) which would turn and then back to the tank.
This is a simple 12v circuit.
If you took the water wheel (lamp) out of the system and turned it on the water would flow through the system and with nothing to slow it down eventually, because of the speed of the water the system would explode.
This is what is know as a short circuit, this can and will cause fires and explosions.
Simple rules
The circuit has to be complete for everything to work
The circuit must have some form of load in it to avoid a short
The circuit must have a fuse placed in it
I am not calling myself an expert but 35 years as a motor mechanic/auto elec. I have learnt a few things.
