Battery and water Meters
boots33
708
679
Just finished installing a water tank gauge and battery monitor and thought i would post a few details on the install.
I didn't need anything too fancy for the battery meter so ended up getting one of these http://www.sidewinder.com.au/page76.html . It shows a single led to indicate the battery level from 10% to 100% (11v to 13v). The Jayco setec power unit will dis-connect the battery at around 10.5v so when the meter shows 10% you know you don't have long to go. This makes it easy for the whole family to quickly see how our battery level is. The meter only draws about 11ma so it can be left turned on with only a minor drain on the battery. I have fitted an on/off switch for turning the meter off while the van is not in use. got the switch here http://www.ebay.com.au/itm/5-Pcs-2-...Electrical_Test_Equipment&hash=item3f152adf2f .
Our van did not come with a gauge fitted to the water tank and as we only have a single tank I was keen to have some way to monitor the tank level. I ended up buying one from R V Electronics as they looked to be fairly easy to fit (bit lazy). Got it from here http://www.rvelectronics.com.au/page.asp?parentid=3&parent2id=73 They have meters to suit multiple tanks as well. I bought the sender with 5m lead as i thought that would be long enough but it turned out to be a few meters short. Fortunately the wire they use is just standard 6 core alarm wire (get from Jaycar or Dick Smiths) so it was an easy job to extend it.
We have the 150ltr fridge in our 14 so this gives us a great area above the fridge to install the gauges (and some other future additions) so the first thing i did was to take a peak into that area with an inspection camera to make sure jayco didn't have any surprises in there for me. Turns out to be a big empty cavity with just a heat shield from the fridge at the rear, so i was good to go.
The perfect place for fitting ............................................Inserting the camera for a look see
The Gauge packing makes a good template..........................A Dremel makes the job easy
File the hole for a good finish............................................Do the same for the water meter
checking tank for internal obstructions................................Measure and mark where to drill
There wasn't enough room to fit the drill so I used a right angle attachment(available for less than $20 at bunnings) rather than dropping the tank down to gain access. use a good hole saw (22mm for this sender) and drill on a very slow speed, the tank is quite thick and will take a little while to drill through. Don't be tempted to speed up the drill speed as this may deform the hole. be careful as the hole is completed not to drop the plastic cutout into the tank. once done clean away any burs around the hole.
Insert the sender and tighten as per the instructions, you should not need to add any silicone etc to get a good seal. Be careful not to over tighten the nut as this will distort the rubber grommet. I marked the nut with a permanent marker so i could tell when i had turned it one turn passed finger tight. Next you can run the wiring back to the gauge. The plug is fairly large so to avoid drilling a big hole in the van floor i removed it while running the wiring. It is easy to do just use a paper clip to depress the retaining pins while pulling gently on the wire. you may need someone to hold the plug while you do this. Remember to observe the way the pins come out and which colour goes where so you can re insert them later.
I followed original jayco wiring where i could and then ran the wires along the top back of the cupboard. A few P clips keep the wiring neat. I also made a large hole to access the area behind the panel i have mounted the gauges on, this makes it an easy job to mount and connect everything up. You could use an old coat-hanger to drag the wires forward if you don't want to have the big hole. Once connected you can cover the hole with a blank wall plate so it looks neat, you could even mount a flat light there for the cupboard instead.
All finished and ready for our next off grid camp. This is a great area on the 14 for adding things so put some thought into what you might like to add in the future and run the extra wiring at the same time. Some items that come to mind would be a sound system or manual switch for a fridge cooler fan. I put an extra 12v outlet on top of the area and we use it to charge our ipads/phones etc. I have connected the battery gauge directly to the battery (through a fuse of course)
7,483
What a great job, Boots, very neat and very useful.
I saw your van out on Friday and figured you were getting ready for a trip. Should have stopped and offered advice. :lie:
Four of us
388
133
Ipswich QLD
A very good idea with the battery monitor. Thanks Boots another job I'm going to have to do.
I have a question for anyone to answer, does a LCD tv drain the battery much and what would be the lowest voltage a battery can run at before either switching averything off and charging the battery or start a geni up. I have been told don't let the battery drop to below 12v is that right?? Any ideas. thanks
shadow75
98
9
Sale, Victoria, Australia
I have a Kogan 22" led LCD, using 23 watts at the moment.. At less than 2A, it's got a lot of tv time to flatten battery..
As far as battery goes, I personally try not to suck more than 50 ah out of my 100 ah battery. I haven't come close to that yet, been mostly sunny days, and battery recharged very quick by Solar. As for voltage, the SETEC has an auto shut off I believe, but not sure how effective.
boots33
708
679
Yeah we got away down to Yamba for five days. weather was very good and the water was warm as well. Passed a lot of jayco's on the way. Any advice from a fellow traveler would always be much appreciated. :)
cruza driver
Hercules
6,551
4,450
Mighty Victoria
Great job Boots and thanks for the step by step pictures too :thumb:
It sure does take the guess work out of the 2 most important things water and power
Four of us
388
133
Ipswich QLD
Thanks for the info guys. I went away for 2 days free camping and I was worried my TV was going to drain the battery even with the solar panel conected. I saw the voltage drop to 12.4v and started to get worried.
shadow75
98
9
Hi there Four of Us,
Battery voltage is not really a great indicator of the state of charge of the battery. It will give you a rough guide only.. The voltage will change slightly, depending on the load on the battery, hence not reflect accurately... For me I choose a watt meter over a standard volt meter.. Easy to monitor the watts used & created. There are plenty of more robust battery monitors out there, but.. $$$$ for what they do.
It's an overcast day today, so finally will get a chance to see if batt will get fully recharged or not after a nights use.
What size panel did you end up putting in?
Four of us
388
133
Ipswich QLD
Hi Shadow
I got a 120w panel installed and it works good.
