Sold 3 x Bike racks for draw bar
Macca_75
433
414
SE Suburbs, Vic.
#1
Hi all,
I have upgraded to a 4 x bike rack so no longer have a need for these. Everything needed to mount it on the draw bar is included. The little aluminium blocks "lift" the rack so it clears the spare tyre - you may not need these but they are included anyway.
$40 ea for all 3 for $100. Local pickup from 3805 or 3151 preferred as the length may drive cost of postage up.
Following 2 pics show the racks fitted and how the bikes sit.
3,067
5,416
victoria
#2
Sold i bloody need them.now going to put young fellas bike on roof rack not bringing the daughters shes shattered im in altona where are you id get them tonight if i could let me know im leaving tomoz at 1pm so if i carnt can you hold them for me till i get back on the 22nd next month well pick them up around then first available weekend ?????
Macca_75
433
414
SE Suburbs, Vic.
#5
Here's what info I have
cyclingdeal.com.au - (03) 9793 9188 - located in Dandenong South
Part number is YT-85835
Description: Alloy Car roof bike rack Bicycle carrier rack with Lock - $65 inc GST
Best ring to check they have stock first.
Bolts are gal bolts from Bunnings - something like this - I can't remember specific size but you can measure it once you have the racks and the van around - https://www.bunnings.com.au/zenith-m8-x-150mm-galvanised-cup-head-bolt-and-nut-4-pack_p2310524 Also get some gal lock nuts to suit.
The cup head slides into the bottom of the rack if you pop the plastic end off. I put a washer under the rack so the bolt doesn't pull through
I only put the aluminium block in to lift the rack over the spare wheel - you may not need this.
For the bottom plates, something like this - https://www.bunnings.com.au/dunnings-150-x-150-x-75-x-6mm-m12-galvanised-angle-bracket_p1070081 - and cut it into 2.
1,891
2,705
#6
Thanks for the info @Macca_75
Likes: Macca_75
1,891
2,705
#8
So after your help @Macca_75 I purchased a rack from cyclingdeal.com.au, great service, had it delivered to me within a couple of days, even though I ordered between Christmas and New Year.
Ended up with a great rack whcih I made a couple of minor mods to and put up on the roof rack. Worked perfectly on our trip a couple of weeks back
Likes: Bluey
Macca_75
433
414
SE Suburbs, Vic.
#9
Hi Macca,
I’m looking to find a bike rack for 4 bikes, I was wondering what you replaced these with? Did you go with another drawbar mount?
Hey @heathm - I ended up with a isi 4x4x4 (with an additional hitch for the car so I can swap the carrier between car and van in about 1 minute.
http://www.isi-carriers.com/products.html
Cost a bomb, but the bikes are rock solid and take < 30 secs per bike to put on/take off.
Macca_75
433
414
SE Suburbs, Vic.
#10
So after your halp @Macca_75 I purchased a rack from cyclingdeal.com.au, great service, had it delivered to me within a couple of days, even though I ordered between Christmas and New Year.
Looks good - your travelling height is higher than the van o_O not so much the wind drag but gee you need to look out for the trees.
Oct 19, 2017
9
Vic
#12
Hey @Macca_75 I have been looking at the isi. How did you mount the isi to the van? Do you have any photos I just can't see how it could fit on mine. Expanda 14.44 Outback
Macca_75
433
414
SE Suburbs, Vic.
#13
Hey @Brad Hardwick - have a chat to George at ISI Carriers and let him know you van model (and wether or not you have an extended drawbar and if it is touring or Outback model (specifically 4" or 6" A frame)). He sells mounts. You can see the bracket from the photo below what they look like (this is pre bolting it on). I had to move my ESC controller and ESC indicator light. I bolted the post to the mount first, then attached the mount to the A frame.
The mount comes with the required U bolts, etc. You won't need to buy anything else if you buy his kit.
Likes: 1DayIll
