17Triton's Starcraft 17-58-3 OB
17triton
3,717
5,438
Ballarat
Got rid of that crappy little drop down thing and installed a drawer for the cutlery. Much better and will get a lot of use as it can still be opened with the bed extended out.
17triton
3,717
5,438
Ballarat
I've been busy on the underside of the van as well doing a bit of stone protection with the foam as well as corrugated tubing over the brake wires and other wires as well as insertion rubber mud flaps to protect the shockers and tank sensors. I am baffled how Jayco can just run their pipes and wires over sharp edges of the chassis and rails with no protection from rubbing through.
expanda
Site Founder
3,892
1,961
Western, Sydney....
View attachment 57003 View attachment 57004 View attachment 57005 View attachment 57006
Fantastic work mate very cleanly done!
19,476
I did that on my old 14 as well as Big Mal, but sleeved the water lines that way I made sure the Guest fittings were all homed nicely..........not only protects from rocks and chaffing also stops the lines from freezing, tested at \warialda and canberra.
2,651
3,817
Nice hitch you asked my question @DaveR and i now have the answer thanks @17triton ive wanted one of those hitches for a while but forgot all about it did you get it from a shop or online mite have to spend some hard earned
JS4910
148
452
Gladstone Central Qld
Where did you attach the insertion rubber to for the suspension protection, I have a fair bit and am looking to fix up a few bits around the underside of the van.
17triton
3,717
5,438
Ballarat
Just cable tied it from the top cross bar on the swing arms and let it hang.
