17' Series 17-56.2 Outback - Hyland Coupling
shadow75
98
9
Sale, Victoria, Australia
G'day Guys,
With a new 17-56.2 Outback on order, I'm considering adding the Hyland Coupling to the list of options (if the budget stretches) I would love any advice or experience out there as to what works well.
A couple of quick questions:
-Does the Hyland coupling still work effectively with the HR Weight Distribution Hitches?
-At what point / angle do you remove the WDH bars for steeper angles?
-Is there any difference in the ride for Hyland vs Standard Coupling?
-Have you fitted them via Jayco or after delivery? (cost for Jayco vs Aftermarket??)
-Is the hook up time much different from the standard couling?
With a couple of Months until delivery, time seems to be going so slow.
Thanks in advance,
Cheers, Glenn
Moto Moto
1,553
567
The Gong
Hey Glenn,
I have a Hyland Hitch on our 14.44-4OB. Its dead easy to use, and i have tried them all (Standard, Tregg and OzHitch). The Ozhitch was great but got way too greasy on the outside so i decided to try the Hyland this time.
Only had the van a few months but so far so good. No slower than a standard hitch to me.
Can't help with the WDH as i don't run one. We had ours fitted by our dealer ready for pickup. You may also want to consider a 50mm spacer to go under the hitch as well. We need one on our van to keep it level with the Patrol.
bully66672
98
13
I can't see why this hitch wouldn't fit my hay man Reece weight distribution hitch.
As for other brands I'm not sure.
I only remove WDH bars if I'm going slow down unmade roads.
Moto Moto
1,553
567
The Gong
I honestly can't remember. But i do remember that if you order it factory fitted, you don't pay or labour, just parts (its a 10min job anyway). At the time i looked around to see if it would be cheaper for me to put one on aftermarket, but the best price i got was from Jayco, so added it to my order, that way it is all part of the van at delivery (and covered by the van warranty).
shadow75
98
9
Thanks for the replies... I've still got a couple of months until delivery, so a few more weeks to make up my mind.. (and probably add more from the wish list) I can't remember how much I was quoted... Oh well, another phone call :) Does anyone know if the holes for Hyland Coupling are the same as the standard coupling? I guess that is another consideration for factory vs aftermarket.
MolongMick
618
112
52
NSW
Hi Glen I too will be looking at the options for hitches, I was considering the terg style hitch, but have found this hitch , which I think they should be able to install, being that it is AL-KO, and most of the fittings Jayco use are from AL-KO. My calculations is that it is about the same price as the other upgrade options. I was quoted $331, for the treg style hitch, fitted at the factory.
Hope this doesn't confuse things too much
Cheers Mick
